Re: W-30 / F-30 carb overhaul question
Posted by Bob on July 03, 2005 at 23:42:24 from (64.21.249.40):
In Reply to: W-30 / F-30 carb overhaul question posted by Pete in Holland, MI on July 03, 2005 at 22:13:59:
I'll comment on #2 and #4.
Loosen the screws holding the throttle plate to the throttle shaft, and (with the idle speed screw backed off), wiggle the throttle plate around until it best tighly closes off the throttle bore. Then tighten the screws to hold the plate in that position. That likely will help your "idles too fast" problem.
Usually, the screws were originally staked to keep them from falling out and getting sucked into the motor. Loctite also works for this.
Post a Followup
