Re: W-30 / F-30 carb overhaul question
Posted by Bobcat on July 04, 2005 at 08:18:26 from (69.66.79.204):
In Reply to: W-30 / F-30 carb overhaul question posted by Pete in Holland, MI on July 03, 2005 at 22:13:59:
#1- It will go only in one position. There is a orientation slot in the bottom that must line up with the fuel booster.
#2- If there is alot of wear in the shafts it will cause eratic and uneven idleing.
#3- Replace that idle jet It is all one piece and should not be loose.
#4- I would suspect that your governor is out of adjustment and not letting the throttle plate close down to the idle screw.
Good Luck!
Post a Followup
