Re: Cub making noise from transmission with clutch
Posted by Big Don on July 05, 2005 at 12:21:41 from (24.114.127.181):
In Reply to: Cub making noise from transmission with clutch dis posted by GNB on July 04, 2005 at 16:52:24:
Did you replace the pilot bushing in the end of the crankshaft? If not, it is probably dry and dragging. If you did replace it, did it get burred on installation? The noise you describe sounds very much like pilot bushing problems.
When you say the shaft wobbles,that is not uncommon as you have about 3' of shaft hanging out from the end of the transmission bearing and any small amount of play in the bearing is magnified by the length. The pilot bearing centers the shaft so the rear bearing needs to be really bad before it is a problem.
Don
Post a Followup
