Re: Is this doing damage to my 404
Posted by CNKS on July 05, 2005 at 14:36:33 from (204.249.178.138):
In Reply to: Is this doing damage to my 404 posted by Jrry on July 05, 2005 at 13:41:06:
8 feet is quite a bit for a 404. Your tractor should have a tach. A rule of thumb for any operation, pto related or not, is that the engine rpm, loaded at full throttle, should not drop below the pto speed marked on the tach. Or, the engine rpm should not drop below the rated full load rpm -- I don't have that number handy. Another test is to depress the clutch to stop movement, then release the clutch -- the rpm should rise to the rated rpm in about 5 seconds, or less. Any more than that and the engine will probably be straining to make rpm. If it doesn't pass the test, reduce your swath width.
Post a Followup
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
