Is this doing damage to my 404
Posted by Jrry on July 05, 2005 at 13:41:06 from (205.144.229.238):
I have a International 404 that I have been using to pull an 8ft pull type cutter. It works good but I run it in first gear. I only cut about three acres with it but it is heavy grass. The tractor doesn't seem strained but I don't want to damage the tractor. Is this too much mower for the tractor? I think it is about 35 to 37 hp tractor.
Post a Followup
