Re: International Diesel running like a dog... :(
Posted by Hugh MacKay on July 07, 2005 at 02:02:00 from (216.208.58.156):
In Reply to: Re: International Diesel running like a dog... :( posted by Derek Broerse on July 06, 2005 at 21:03:30:
Derek; I have to agree with jossette, either dirty or bad injectors. You can try the fuel additive for cleaning, however if that doesn't work, best to take the injectors to a professional for cleaning or rebuilding. What you may have done cleaning lines, etc. is loosen some dirt that entered an injector after the clean up. What I like doing after working on a fuel system, before connecting lines to injectors, is turn the engine over for about 30 to 60 seconds in the shut off position. I know this makes a mess, but most systems you can put small plastic tubes on injection lines to run fuel to a pail. Another item you should always do is the minute you remove an injection line is have plastic caps to plug the injector inlet. I've even used plastic wrap from the kitchen with elastic bands. Even loose particles floating in the air can partially plug an injector, thus distorting nozzel spray pattern. Never scrape around the injector nozzel with a kinfe, wire brush, etc. Even the slightest scratch and distort the injector spray pattern.
Keeping things clean, a big item working on diesel injection systems. Your kind in the same catergory as a surgeon, while working on an open diesel fuel system. If and when you go to a diesel injection shop, just observe how careful these guys on cleanliness, that is if they allow you in the work room. I know an old time engine rebuilder, who would never assemble an engine with people in shop. He said, "Folks milling about create dust and dirt, don't want that under a rod bearing cap."
Post a Followup
