Re: SUPER C idle too rich
Posted by JOWENS on July 07, 2005 at 09:07:05 from (65.132.114.141):
In Reply to: SUPER C idle too rich posted by JOWENS on July 06, 2005 at 10:10:49:
THANKYOU FOR YOUR HELP.
WHEN I PUT THE NEW POINTS IN I SET THE GAP AT THE HIGHEST POINT ON THE DISTRIBUTOR SHAFT NOT AT TDC. SO I SET THEM AT TDC THIS MORNING, BUT I HAVE ABOUT 20 DEGREES OF PLAY IN THE SHAFT. AFTER SETTING THE POINTS THE TRACTOR RAN SMOOTHER AT IDLE AND THE SPARK WILL JUMP 3/8" TO 1/2" GAP. I STILL HAVE A SMALL AMOUNT OF BLACK SMOKE AT IDLE, BUT I'LL RUN IT A WHILE AND SEE HOW THE PLUGS LAST. SHOULD I WORRY ABOUT THE PLAY IN THE DIST SHAFT. ALSO HOW DO I SET THE CORRECT TIMING WITH THE DIST.
Thanks Jack
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
