Re: Farmall B Exhaust Manifold
Posted by El Toro on July 07, 2005 at 15:05:53 from (205.188.117.73):
In Reply to: Farmall B Exhaust Manifold posted by Leon W on July 07, 2005 at 08:24:19:
Hi Leon, Be careful when trying to remove the pipe from the exhaust manifold that you don't break the manifold. That pipe has probably rusted
over the years. Use an acetylene/oxygen torch to heat the manifold around the old pipe. Put some anti-seize on the threads of the new pipe when you install it. Hal
Post a Followup
