Re: Super C question
Posted by El Toro on July 08, 2005 at 03:34:26 from (152.163.101.13):
In Reply to: Super C question posted by TXfarmall on July 07, 2005 at 20:42:03:
Take your cylinder head to an auto machine shop
that does a lot of autos and truck heads. The valve seat angle is 45 degrees, but as mention by others the machine shop will have all that info in their handbook. They can check the head for flatness too.
You should also take the crankshaft there for measurement and for any machining or polishing.
That should include the block too to remove any sludge and to clean the oil passages.
Make sure that block is clean of all rust and scale where the sleeve seals are installed. Very important to prevent any coolant leakage. Hal
Post a Followup
