Re: SMTA won't quit
Posted by farmallhal on July 08, 2005 at 08:02:42 from (64.24.35.16):
In Reply to: SMTA won't quit posted by Hayfarmer on July 08, 2005 at 07:24:21:
I converted my H over to 12 volt last fall and I have the same problem using just a resistor. I think a resistor is needed to "load" the alternator into a charging mode at startup. I just throttle my H back to a slow idle and turn off the ignition switch and it shuts down promptly. I guess the resistor and diode in combination would be the correct fix and the load would flow to the alternator through the diode but couldn't backfeed back through the diode to the switch so it could keep running.
Post a Followup
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
