Re: 2424 will only run with the starter button pre
Posted by Nat on July 08, 2005 at 09:38:33 from (64.80.110.44):
In Reply to: 2424 will only run with the starter button pressed posted by Paul J on July 08, 2005 at 09:19:46:
Turn the key to the "run" position, and use a multimeter to check the power to the coil. You should be able to touch the + side and anywhere on the frame, and read 12 Volts.
If you don't then follow the wire back to its source. Most likely you will find your problem somewhere along the line, or at the source itself.
Post a Followup
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
