Re: 2424 will only run with the starter button pre
Posted by Calif. Farmall on July 08, 2005 at 14:10:06 from (207.200.116.203):
In Reply to: 2424 will only run with the starter button pressed posted by Paul J on July 08, 2005 at 09:19:46:
I'm not sure how your 2424 is wired however on most early GM Delco systems the extra terminal on the starter soliniod terminal "I" sent 12 volts to the coil only when starting or turning the switch to srart. The points normally run on 6 volts and the extra power helps cold start up.
You should have a regular power sorce to the coil for run position and it may be a resister wire or go to a resister block. Most times I've seen the wire or block go bad or it may hve just come off if it just happened. I normally take a test lite to the positive side of the coil and should lite up in both on and start.
Post a Followup
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
