Got her done!!!
Posted by Kelly C on July 09, 2005 at 15:28:12 from (63.171.43.140):
In Reply to: Re: Ok Hugh, gona try your PTO trick. posted by Hugh MacKay on July 09, 2005 at 02:13:19:
Worked slick Hugh.
Not many bolts but whew that is a beast to get out. Had to use a come along from the hitch on my truck to get her out of the hole.
When it does come out dont lift with your back. That hummer will make you grunt. I slung a belt around the narrow end of the pto when enough was exposed. Slung that over my shoulder. When she popped all the weight was on my shoulders. Just had to hold the pto shaft with one hand.
I used to extra long bolts with the heads cut off as guides when I installed the new one.
Bolted her up, hooked up the baler and finnished the hay.
Post a Followup
