lower bolster removal on M
Posted by Kevin Brooks on July 09, 2005 at 17:50:26 from (64.136.26.225):
I am trying to separate the lower bolster from the upper bolster so as to drop the steering shaft and replace some very leaky seals. I managed to remove the four main nuts from the bottom of the lower bolster and expected the unit to fall off - which it didn't. After removing the two rearward (engine side) bolts I noticed that the two bolts up front seem to have caps on them giving them an acorn nut appearance. Gaining access to these nuts is very difficult as it would appear I need an offset type wrench - which I don't have. Has anyone removed these two bolts and how did you do it? I cannot get the same box end wrench around them as the space between the nut or bolt heads and the casting is two small for my wrenches. I'm fearful of using an open end because I don't want to strip the bolt heads. Any suggestions would be appreciated.
Post a Followup
