Re: lower bolster removal on M
Posted by DWV on July 09, 2005 at 18:25:34 from (205.188.117.73):
In Reply to: lower bolster removal on M posted by Kevin Brooks on July 09, 2005 at 17:50:26:
Sometimes the 4 bolts and holes in lower bolster
rust and make it hard to slide off bolts.The tall headed bolt goes in front right corner with wheels straight ahead.Should be just one with tall
headed bolt.If you want to get at heads on 4 bolts
and were planing to remove shaft anyway,remove nut
on top of shaft and let it drop down a few inches
with tractor jacked up.No problem getting wrench
on then.
Post a Followup
