Farmall H steering shaft
Posted by CurlyLumber on July 09, 2005 at 17:51:46 from (67.138.152.91):
I need to change the support that holds the amp box, steering wheel shaft, hyd. lever. The problem i"ve run into is the nut for the steering wheel is seized on there(someone has banged the extra threads over so its mushroomed over the nut). I cannot remove the support without removing that (correct?). Does the steering yoke screw into the shaft? What would be the best way of replacing this item? Thanks
Post a Followup
