Re: 460D Running, But Not Too Good
Posted by Ron Smith on July 11, 2005 at 10:13:39 from (205.188.117.73):
In Reply to: Re: 460D Running, But Not Too Good posted by JakeF on July 10, 2005 at 19:14:22:
Thanks! I"ll pull the leaking injectors and clean out the bores better. There probably is some carbon in there. I thought the 0 rings had something to do with the seal.
Maybe once the leaks are stopped, it will run better. Seems like this tractor will have a lot of power once running right. Wish I could get it timed right though. I can turn the pump to some degree to time it. I guess I will rotate it one direction and see if that improves anything. Not sure which direction to go first. Thanks again.
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
