Re: hyd. on super M
Posted by makin' hay on July 12, 2005 at 17:51:51 from (66.181.140.91):
In Reply to: hyd. on super M posted by Truman DeVault on July 12, 2005 at 15:29:22:
the belly pump, if that is what you have, has 3 ports. 2 are instant pressure and one is a delayed port for trailing impl. that you want the rear to raise after the front. it was designed for lift-all rams which are single acting cyl. power up...float down. this can be overcome by adding an IH optional remote control valve. this is installed with the belly pump valve in the on position which then supplies pressure to the remote valve. it then gives you power up and power down. very handy for a haybine and such. otherwise single cyl. are good for sickle bars and the like. hope this helps and welcome to the wonderful world of M ownership.
Post a Followup
