Re: Deisel injector pump
Posted by Ron in Nebr on July 12, 2005 at 23:00:48 from (65.172.143.46):
In Reply to: Deisel injector pump posted by Richard Fazio on July 11, 2005 at 17:43:38:
I tried to post last night but it didn't come up, so here goes again..... Check the simple things first, like the screen mentioned below. It's in the inlet fitting on the primary pump. Also, wouldn't hurt to make sure the petcock on the bottom of the deisel tank is open! The fuel on these goes through the water separator, then the primary(rear) filter, then through the primary pump, then to the secondary filter, and then to the main injection pump where the guage is. If you have fuel at the bleeder on top of the primary filter you're ok up to that point. Sometimes if the tank is low it won't gravity bleed through the primary filter. Pull the output line off at the primary pump and see if there's fuel coming out there while it's running on gas. If not, then there's problems in the primary pump. There's a pressure relief valve in the primary pump that could be stuck. The gears in the primary pump are driven by and secured to the shafts by small roll pins. One of these could be sheared. In a worst-case scenario, you may have the same problem I had on my 650D. The primary pump is driven by a small square hex that's machined onto the rear of the governor shaft inside the main pump. On mine, this square hex was rounded off and the primary pump didn't turn. I had to pull the whole thing apart, weld and file the square hex back onto the rear of the governor shaft, and then it all worked fine again. Had to make almost all the gaskets myself, but some of the seals are still available from IH and other places. Good luck!
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
