Re: Cub Trasmission help!
Posted by Jim Becker on July 13, 2005 at 19:14:07 from (71.96.6.168):
In Reply to: Cub Trasmission help! posted by GNB on July 13, 2005 at 19:02:08:
If it is the upper gear, you have to split the tractor in front of the transmission. Then you can remove the upper shaft from the front, freeing the gear.
If it is the lower gear, you have to take the whole thing apart. The lower shaft comes out the back, which requires pulling out the differential assembly.
Post a Followup
