Re: B-250 Questions
Posted by Michael Soldan on July 15, 2005 at 04:42:51 from (24.235.43.38):
In Reply to: B-250 Questions posted by Mark Bourne on July 14, 2005 at 12:27:50:
Mark, I brought a B250 home a few years ago that had been sitting for 8 years.I could only start it with ether. Once home I began using an injector cleaner additive and each subsequent treatment made it start easier and easier. I suspect your injectors may be "slobbering " instead of spraying, try injector cleaner, it may do the trick. The other response to your post is quite correct, that trans filter is in line, a tiny mesh screen inside the connection on the right hand side of the trans...it is tiny as it is inside that hydraulic line.....Mike in Exeter Ontario
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
