Re: B-250 Questions
Posted by MJ in the UK on July 15, 2005 at 09:44:10 from (195.92.168.174):
In Reply to: B-250 Questions posted by Mark Bourne on July 14, 2005 at 12:27:50:
The B250 is a great little tractor. Made here in the UK starting with serial number 501 (i have no 549) I suspect you have a worn hyd pump as your loader works better when the oil is culd and thicker if it was a blocked filter the loader would work better when the oil was warm and could pass through the filter. Remove and clean the wires between the glow plugs to make them work better also the wire between no 4 plug and earth bolt on the timing case. GOOD LUCK MJ
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
