Re: No Electricial power
Posted by El Toro on July 16, 2005 at 17:03:19 from (205.188.117.73):
In Reply to: No Electricial power posted by Power Tool Joe on July 16, 2005 at 16:44:04:
You need heavy duty battery cables and make sure
all rust and paint is removed in the area where
your ground cable is and is tightly secured. Clean all battery terminals and battery cable spades. If you still have the 6 volt system these old tractors used a positive battery ground.
Hal
Post a Followup
