Re: Follow up on Cub quit
Posted by El Toro on July 18, 2005 at 09:52:33 from (205.188.117.73):
In Reply to: Follow up on Cub quit posted by Farmall Ed on July 18, 2005 at 09:27:31:
Your rotor should be aligned with NO 1 plug wire
in the cap when No1 piston is at TDC on the compression stroke and when the notch on your pulley is aligned with pointer. You must be very close since it is running.
Pull No1 plug and hold your thumb over the hole while someone slowly cranks over the engine, by
hand would be the best. You can check that timing with a timing light and see where your
timing mark is at now. I have an inductive light
that you just clip over the plug wire, hook power
leads to battery and start engine, if off slightly just rotate distr until pulley notch is
aligned with pointer. Hal
Post a Followup
