Re: Hydraulic Lift Arm - 300 Utility
Posted by TDK on July 18, 2005 at 17:36:41 from (152.163.101.13):
In Reply to: Hydraulic Lift Arm - 300 Utility posted by jsmith18 on July 18, 2005 at 14:40:14:
If you're speaking of the left arm. The hole is for a pin, to make lift have down pressure. Without pin lift will float.
Post a Followup
