Re: Hyd leak on C
Posted by CNKS on July 19, 2005 at 18:05:09 from (204.249.178.138):
In Reply to: Re: Hyd leak on C posted by agpilot on July 19, 2005 at 13:50:13:
Seal is on the pump shaft, obvious when you remove the pump. The shaft may be grooved, requiring a "speedy sleeve" (about $25). The seal can be either rubber/metal or a simple o-ring. If an o-ring, the hole in the housing that the shaft goes through will have to be enlarged to accept the sleeve.
Post a Followup
