Re: Hyd leak on C
Posted by agpilot on July 19, 2005 at 13:50:13 from (12.214.196.188):
In Reply to: Re: Hyd leak on C posted by Randy in NE on July 19, 2005 at 10:19:56:
Hi Randy in NE.
I like your answer.. and no I won't ask you how you found out there is pressure inside.. (grin.. I've done that sort of thing too)
Yep.. it was real low. I'll find something like IH HiTran to add and try again. Maybe I'll luck out by just filling it.. but like Ken said it's common to loose a seal..
That means I'll have to ask where is that seal? Between the pump and the engine block that it's mounted to up front?
Anybody comment on if it's a Tricky or fairly straight foward repair job?
Thanks. agpilot
Post a Followup
