Main shaft Bearings wobble in Toxowick Dryer
Posted by andy r on July 19, 2005 at 22:23:18 from (69.66.148.108):
I have a Tox-o-wick batch dryer (500 bushel) which drives off of a tractor PTO. The PTO drives a three foot 1 1/2 (approx) inch diameter shaft back in underneath of the dryer. The shaft runs the fan, recirculating auger, the stirring arms and the loading augers. These components are all ran by belts. The shaft is supported on each end by bearings supported in bearing holders. The bearing comes out of the holder by turning the bearing sideways. My question is when you turn the shaft slowly you can see both bearings move in and out ever so slightly at the top. Is this caused by a bent shaft? Bad bearings? Worn bearing holders? Improper aliment? If the shaft is slightly bent can a machine shop straighten it? Any help is appreciated. Thanks
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
