Re: Gas in oil
Posted by RustyFarmall on July 20, 2005 at 04:43:15 from (216.248.75.145):
In Reply to: Re: Gas in oil posted by mike3501 on July 19, 2005 at 20:40:08:
Are you sure it is gas? I don't think there is any way that a bad carb could possibly leak gas into the engine, even if the needle valve was not working at all the gas would still run out of the carb long before there was enough accumulation to run into the engine. It would have to fill the carb, fill the manifold, and then go in past the engine valves.
Post a Followup
