Re: IH 1466 - same problem
Posted by SGT K on July 21, 2005 at 11:15:20 from (216.125.213.242):
In Reply to: IH 1466 - steering - MVC problems posted by Murphy Ranch on July 20, 2005 at 18:50:52:
I'll be watching this post because I occasionally have the same problem with my 14. There seems to be no rhyme-or-reason as to when it might act up. When it happens it is usually immediately on start up. It acts like it won't take prime. I also find that if I shut it off and remove the flow divider and clean it up it will start working. I tried running it two gallons over full on oil, but that didn't have any affect.
I notice that the spool in the flow divider is a little scored and scratched. I was surprised at how mutch grime and dirt was in the bottom of the rear-end and transmission last time I was in there. I do not think the filter system is all that efficient, because I change the filter often.
Next time i'm inside the tranny or rear-end I'm gonna clean it up again and change all of the fluids. Maybe dirt is causing the sticking spool?? Anyway, I'm sure there is someone here who has fixed this problem. Good luck.
Paul
Post a Followup
