Re: 400 hot hydraulic fluid
Posted by Mac on July 22, 2005 at 08:15:37 from (217.144.243.200):
In Reply to: 400 hot hydraulic fluid posted by JimJP on July 21, 2005 at 10:51:34:
If you're sure something is wrong, hear any squealing? My guess would be relief valve, cushion valve or priority (steering) divider.Have you tried to lift anything heavy yet?
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
