Re: FAA clutch adjustment
Posted by Janicholson on July 22, 2005 at 14:21:15 from (66.173.50.109):
In Reply to: FAA clutch adjustment posted by Kendog on July 21, 2005 at 10:41:09:
Dear Kendog,
Bearer of the news A clutch that engages near the top of its travel (almost all the way out) is adjusted incorrectly. (should be about an inch and a quarter of play before the operator feels the pressure of release. But!!!! in that adjustment position, the travel of the clutch mechanism is near the maximum. This means that when the pedal is pushed all the way in, the clutch is even more released than when adjusted correctly. If your clutch is dragging, (as indicated in your post) adjustment will not fix it. The pilot bearing may be binding (possible) or the disc may be warped causing drag when pedal is depressed. Ive also seen rusted up splines on the input shaft to the trans cause dragging. In all these cases the clutch needs to be repaired (not impossibly hard, just a little strange). Follow the book.
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
