Re: Super A Hydralics problem
Posted by Hugh MacKay on July 22, 2005 at 16:13:19 from (216.208.58.168):
In Reply to: Super A Hydralics problem posted by Kyleg on July 22, 2005 at 15:59:41:
Kyle: Check your crankcase oil pan level. If you cant see the leak, most likely it's leaking along the hydraulic pump shaft and into the crankcase.
Post a Followup
