Re: Farmall 130 flywheel replacement
Posted by Hugh MacKay on July 23, 2005 at 18:19:27 from (64.228.12.152):
In Reply to: Farmall 130 flywheel replacement posted by Lee in NC on July 23, 2005 at 12:14:51:
Lee: Remove the starter, and take a look those rings are double sided and you can turn them. You may already have new. On splitting the tractor, I first drive wooden wedges under the front axle stops so the offset engine can pivot when you unbolt it. I then place a hardwood pallet under the front axle going to a point even with back of engine. I then use blocking on each side under the axle. I also block the back of engine under the oil pan. Yes, right under oil pan. I use a 2x10 for my top block under pan and place one of those gardeners knee pads between the 2x10 and pan. I then tie it front end to pallet with ratchet straps. I block the rear wheels, place a bottle jack under clutch housing and place a pallet jack in pallet. Jack the two in unison, unbolt the tractor and you can roll front where ever you wish. Works best if you remove steering wheel. This works excellent for rolling it back together. I can change a clutch in one of these in about 4 hours all by myself. I have use the same on a Farmall 560, again all by myself, just takes a bit longer. When you get to the flywheel, the ring gear is sweated on. If just turning it be careful not to use too much heat, and keep it uniform around the ring. To give you some idea, you can warm the ring enough in oven to put it back on. Some say you can warm it enough in hot water, don't know never tried it. That give you some idea how little heat this requires. Any more questions just shout. By the way a new ring gear will be under $50.
Home
| Forums
Today's Featured Article -
Restoration Story: 1951 Farmall H - by The Red (John Fritz). I have been a collector of Farmall tractors since 1990 when I first obtained part of the family farm in Eastern Indiana. My current collection includes a 1938 F20, 1945 H, 1946 H, and the recently purchased 1951 H. This article will focus on what I encountered and what I did to bring the 1951 NEAR DEATH Farmall H back to life.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
