Re: 1950 Farmall H : 12V or 6V??
Posted by RustyFarmall on July 25, 2005 at 05:59:55 from (207.32.13.234):
In Reply to: 1950 Farmall H : 12V or 6V?? posted by Bernard M on July 25, 2005 at 05:47:12:
IF the tractor had ever been converted to 12 volt there most likely would have been a ballast resistor in the wire that fed the coil, meaning that your coil is probably a 6 volt coil. The starter also is most likely the original 6 volt starter, 12 volts will not hurt the starter. The light bulbs, either 12 or 6 volt will fit in the same socket so you can go either way.
Post a Followup
