Re: farmall h starts but but runs only with choke
Posted by old on July 25, 2005 at 07:32:22 from (207.69.136.198):
In Reply to: farmall h starts but but runs only with choke out posted by charlie marshall on July 25, 2005 at 07:18:18:
Well that means you have one of 2 problems. You aren't getting gas to the carb or the carb still has a problem. Gas in the oil means the float needle seat was not working like it should have the the gas ended up in the oil because the float needle wasn't shut offf the gas it it filled the carb and then went in to the oil. If it only runs choked it means its not getting enough gas. The main jet may still be clogged or the tank or line is clogged
Post a Followup
