Re: farmall A valve timming setting
Posted by Red Dave on July 25, 2005 at 10:07:25 from (24.104.94.34):
In Reply to: farmall A valve timming setting posted by Tractorfrank on July 25, 2005 at 09:59:49:
Not sure what you need.
The timing mark on the flywheel should be lined up with the pointer on the inside of the cover that goes in front of the flywheel, just behind the oil pan.
You probably have the spark out of time. Set the valves at .014 clearance hot. I usually set them at about .016-017 cold, then fine tune after the engine is warmed up.
Does that help, or did I miss the question?
Post a Followup
