Re: farmall A valve timming setting
Posted by scotty on July 25, 2005 at 11:26:52 from (199.231.49.128):
In Reply to: farmall A valve timming setting posted by Tractorfrank on July 25, 2005 at 09:59:49:
TractorFrank,
Find the scribed line on your flywheel. Mark it with a white marker. Remove your #1 sparkplug. While your helper hand cranks the motor over slowly put your finger over the plug hole until you feel pressure coming out your now on the compression stroke. Keep rotating the motor until your scribed line is in position on your flywheel. Remove your valve cover. Adjust #1, #2, #3 and #5 valves to .017. Now hand crank your motor 1 revolution and adjust #4, #6, #7 and #8 the same way. Rotate your motor 1 more revolution to bring you back to TDC. Remove your cap on the magneto, your rotor should be pointing to the #1 plug wire. Hopefully this will help.
scotty
Post a Followup
