Re: sheered bolt on super a
Posted by El Toro on July 26, 2005 at 13:04:59 from (64.12.117.13):
In Reply to: sheered bolt on super a posted by PaulH on July 26, 2005 at 12:42:00:
If enough of the broken bolt is protruding I would
weld a nut to it and then see if the broken bolt
can be backed out. Apply a little anti-seize to the threads of the new bolt. The heat will help to loosen the bolt. Hal
Post a Followup
