Re: Paint Gun recommendations
Posted by CNKS on July 27, 2005 at 08:43:22 from (204.249.178.138):
In Reply to: Re: Paint Gun recommendations posted by Dave in CT on July 27, 2005 at 06:08:27:
There are two types of HVLP, one is the self-contained turbine system Andy used, the other is a gun that uses an air compressor. All the air compressor type HVLP guns I have seen are gravity feed. The advantage is no drips, they don't sputter, they simply run out of paint. I'm not going to get into the price/quality thing, but I have a Sharpe Cobalt as a primer gun, and a refurbished (half the price of new) Sharpe Platinum -- an excellent gun, not the world's best but very good. If you are not going to paint much, buy the cheap gun. If you are going to paint several tractors, get the "lifetime" guns to begin with, you won't regret it. Most HVLP guns are easy to adjust, if I remember correctly, set the paint flow wide open, then back off a quarter turn, the air adjustment is similar, I have this written down, haven't painted in a while, I can look it up -- these are HVLP adjustments, not gravity. Set the air pressure to 40-50 lbs (it will say on the gun) AT THE GUN, using the paint regulator on the wall. Remember these instructions are all for HVLP. Many people who use conventional or siphon feed guns do not like HVLP, because it is slower and requires a different technique. I assure you, since you are a new painter, get an HVLP gun -- you WILL like it.
Post a Followup
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
