Re: Paint Gun recommendations
Posted by Correction on July 27, 2005 at 09:27:33 from (204.249.178.138):
In Reply to: Re: Paint Gun recommendations posted by CNKS on July 27, 2005 at 08:43:22:
The instructions for adjusting HVLP I gave above are not entirely correct. I got these from a person who posts on www.paintucation.com, whose handle is GaryL. These are for a Sharpe Platinum, but I believe they apply to any HVLP gun, if anyone is interested:--Turn the fluid control all the way out, until it is about to come off the threads. Pull the trigger (NO air to the gun!), turn the fluid control in until it touches the trigger, you will feel resistance, then turn an additional 1/2 turn. For the fan control, turn the control all the way out, then back in 1/4 turn. These adjustments will likely need very little modification. Further info -- The distance to hold the gun from the surface is about 6 inches. Close your eyes, pull the trigger with the air connected, hold your hand some distance from the tip of the gun, slowly move your hand or the gun closer, until you feel "a wall of air". Open your eyes, it will be about 6 inches. This is the maximum distance to hold the gun from the surface, and gives the correct atomization. The adjustments are for a full pattern. Although pressure, fluid, and pattern width are adjustable, guns function best when "wide open", and require, IMO, an excessive amount of fiddling if you want to paint a smaller surface. For smaller parts I use a touch-up gun.
Post a Followup
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
