Re: What is the problem?
Posted by El Toro on July 29, 2005 at 07:23:18 from (205.188.117.73):
In Reply to: What is the problem? posted by McDiesel on July 28, 2005 at 23:21:15:
Are you sure the sleeves were replaced or just did a ring and valve job? Could have a pin hole in a sleeve. Hal
Post a Followup
