Re: Squealing Rear Axle on H
Posted by riverbend on July 30, 2005 at 19:44:22 from (208.160.34.132):
In Reply to: Re: Squealing Rear Axle on H posted by Dave in CT on July 30, 2005 at 19:15:22:
The seal should not be tight enough to squeal. You might try squirting a little grease under it with a horse sized hypodermic needle and see if that makes any difference. I have never had grease appear at the seal when greasing the rear axle.
Post a Followup
