Re: International 300, rear end fluid white
Posted by TDK on July 30, 2005 at 21:37:20 from (152.163.101.13):
In Reply to: International 300, rear end fluid white posted by Jim Spenst on July 30, 2005 at 18:07:21:
The check plug for trans & rearend is on the left side underneath the footrest. The drain plugs are under rear of tractor and the other is directly under the check plug on bottom of trans. You can use 80W90 or similar weight gear oil, unless tractor has T/A, then I would recommend Hy-Tran from CIH.
Post a Followup
