Re: wheel weights vs fluid in H rear wheels
Posted by ChadS on July 31, 2005 at 09:41:20 from (66.228.96.217):
In Reply to: Re: wheel weights vs fluid in H rear wheels posted by colekicker on July 31, 2005 at 09:24:55:
But wont be as soft as a tire with just air. the water helps hold the tire from buckling, and yes, any tire can buckle in the center, older tires dont so easily as newer ones, a bit stiffer, and thats why pullers seek them out so much. I belive if you know how to set up a new tire so it does not bend the bars back so much, it would work on about any surface, loose tracks will dig, but if you had the liquid in em, and drive it and not just go out an run wide open, it will hook up easire than one with wheel weights. Ive often thought of filling my cut tires bout 1/2 way up and try it, My 15.5's on a 16 inch rim, can buckle the centers at 13 psi, at 14 psi they dig the track too hard and well, hello China!! Tire pressure is relitive to track conditions, harder tracks, Ill run 12-13psi, and on looser tracks, 13.5-14 and run a set of wheel weights to help bite the ground, but, it usually bites me,, and mess up the balace of the frame, if I can get the tires to hook, and leave the weights for balance purposes only, Id have it made, only thing I can think of to do that is to add some liquid weight to the wheels so it will have a heavier footprint, and not affect the side wall of the tire so much from overweighting the axle. I do belivethat water will make the tire harder inbetween the tire casing, and the rim, air, can move to the top of the tire, and ballon it sightly, where water holds in place cause gravity holds it there, and can take more pressure in the cases where it can buckle,,, ChadS
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
