Re: Super H wont start, electral prob.
Posted by TheDurk on March 10, 2009 at 18:41:32 from (71.251.33.50):
In Reply to: Super H wont start, electral prob. posted by Hugh MacKay on March 10, 2009 at 15:43:04:
All of the above is good advice. Another possibility is points never opening inside distributor (adjusting screw came loose, perhaps) or a short to ground (failed condenser, or condenser wire shorting to case). I would first to do the spark test, and expect a fail. Then I'd use light or VOM to check coil wire at coil and key switch (with points open). If you do the hot wire jump to coil, be sure to pull the existing one as we suspect a short to ground. If that fails, and voltage is good to the coil, , then I'd test voltage along the way from from coil to moving point. Also make sure voltage disappears when points are closed. That done, you begin to suspect the coil itself.
