Int'l. 300 govenor
Posted by davids on August 02, 2005 at 05:27:12 from (66.55.237.212):
The govenor seems to be not controlling the top speed on my 300. I noticed the oil had some gas in it, making it really thin. Will this cause my problem? I"ve drained the oil and had rather check now with you before I refill it. If not the thin oil, which cover will I need to pull off to get to the govenor"s parts to repair it? My oil pressure is 25 at high idle and about1 or 2 at low idle. Should I pull the pan to clean/check for sludge on the screen while the oils out? Any help is appreicated. Thanks, davids
Post a Followup
