Re: IH 464 water in oil
Posted by JB2 on August 03, 2005 at 20:58:09 from (69.196.154.214):
In Reply to: IH 464 water in oil posted by Farmall404 on August 03, 2005 at 06:42:21:
Hi Farmall404, if it is a D206, 4 cylinder Diesel then it is probably leaking around the "O" rings at the bottom of the sleeves.
My Dad had this happen to his 454 D179. He was plowing with it in the farthest field from the shed and the fan belt broke so he thought he would just drive it back to the shed. Well when he got back to the shed the water temp guage was up to the red. After it got cold that fall it would leak antifreeze into the oil. Drained all the crankcase oil and left drain plug out and put a little air pressure on rad and antifreeze would drip out the crankcase drain hole.
Replaced the "O" rings and tractor is still running 15 yrs later.
JB2
Post a Followup
