Re: Letter at the end of the serial #
Posted by CNKS on August 04, 2005 at 19:22:55 from (204.249.178.138):
In Reply to: Re: Letter at the end of the serial # posted by Bill57 on August 04, 2005 at 13:06:21:
You probably don't need any adjustment. As elevation increases, power decreases. I assume the 5000 ft pistons result in more compression. Although not likely, if the tractor is fully loaded and you hear spark knock, the timing should be retarded slightly. The H my dad had (also sea level) would ping occasionally under full load, in a particularly tough spot in the field. Timing was probably off slightly. Nothing serious, just something to keep in mind. You don't do anything to the carburetor.
Post a Followup
