Cub update on cutting off! FIXED!!!
Posted by GNB on August 07, 2005 at 17:48:38 from (205.188.117.73):
Thanks to ones that helped. The cub is fixed. The carb had the wrong needle and seat in it. I had bought one from TSC and did not pay any attention when I rebuilt it that the needle and seat was not the right one. Assembled the carb and she ran fine untill under a load and bam cut off. Went to local Case IH or CNH and bought the correct needle and seat. The one at TSC was a little longer causing it to screw in to far not alowing enough fuel in the bowl when under a load. BEWARE OF TSC REBUILD KITS ON THE CUB.
GNB
Post a Followup
